(Some steps are optional and can be skipped.)
- In a document, create a node (a list item) called
foobar. - At the node context menu, Get link to copy a link to this specific node.
- Either in the same document or in any other document, create a new node, and paste the link. Letās call this new node
linkylink. - Now we have
linkylinkpointing tofoobar. Both forward link and reverse links work fine. - (skippable) Now move
foobarto become a child of any other node. The links still work fine, as expected. - (skippable) Now move
foobarto become a child of a node from a different document. (Either by drag-and-dropping, or by Move to item from the context menu.) Everything still works fine, the links are correctly updated to point to the location in a different document. - Now move
foobarto become a new document on its own.
The links to foobar should still work, like they still do in steps 5 and 6. From the userās point-of-view, step 7 is not much different than step 6.
The link breaks. Any links to foobar become outdated and point to an invalid node. This behavior is surprising because steps 5 and 6 work fine. Itās probably a corner-case that was missed while coding this feature.
Untested
The behavior for links pointing to the inside of the foobar subtree (i.e. links to foobar descendants) was not tested. Thatās something that should be explored and taken care of when fixing this bug.
(None of this matters, the issue is certainly server-side anyway.)
Which operating system are you using? GNU/Linux.
Which browser are you using? Google Chrome.
If youāre using a desktop or mobile app, whatās the version number of Dynalist? Web version.
Are you using any third-party scripts for Dynalist, e.g. PowerPack? Nothing. Just the vanilla experience.
A few related threads:
