(Moved from Trello; you can vote for this feature and see past discussion at https://trello.com/c/N2ilb1oo/135-split-screen)
Similar to Sublime Text, this split screen feature would allow you to see multiple documents side by side. You can control each âscreenâ separately.
Maximum number of screens would be 3-4. 2 screens would still be the most common use case imo.
Problems to figure out:
- Once there are multiple screens, itâs unclear where the document should open when you click on the title of a document. Having the file pane appear in each screen would eat up a lot of the space. Possible solution: the document would open in the screen that youâre focused in (or last focused in).
