The template is using ISO week numbers, where a weeks starts on Mon and week 1 of the year is the week of the first Thursday of the year. So for year 2021, Jan 1-3 fall on week 53 of 2020. Hope I got that right, let me know if I messed up.
Update: I changed the sheet from published to shared. You can see formulas now, which hopefully is enough to create a 2022 template when the time comes. Comments are not visible, unfortunately.
Update 2: Changed sharing from âviewerâ to âcommenterâ. You can see the comments now.
Have you tried selecting O1:Q437 and copy/paste to Dynalist? Does it make a flat list? I donât know why, but if I paste to Notepad first, and then copy from there, then it gets pasted to Dynalist as a hierarchical list, as expected.
I used your gsheet template to help me shortcut the creation of my usual 2021 planner, and I updated my original post with a link to a copy-able 2021 dynalist planner over here: **UPDATED FOR 2021** Here's my Yearly Planner Template
(I made one small change to your template because in the dates I prefer to put a dash in between the month and the day e.g. mm-dd instead of mmdd)
Sorry for late reply, I am not using Dynalist actively ATM. It seems Daryl took care of everyoneâs yearly planner needs after all . I just wanted to confirm, there are no formulas for Col N onwards, it is a manual âcopy and dragâ process, since I could not come up with a way to place month names correctly.
As noted in the comment in cell F1:
This is an approximation, youâll have to drag month nodes manually at the end. If the first one is December, youâll have to delete a number of cells to pull the rest of the months up."
Cols O-Q is where these manual manipulations are meant to take place, as described in the comment in cell O1:
Paste values from F-H columns, and drag months as required, also inserting cells in P-Q so every month is on a line by itself."
So yeah, the spreadsheet is only a crude tool that lets you create the next yearly template faster. It wonât do it for you. Cheers.
