Launch Dynalist in browser with theme set to āDefaultā in settings.
Expect that Dynalist should have a white theme.
Dynalist is displaying with a dark theme. It is not possible to get a light theme when selecting all the different theme options in the settings.
macOS Catalina 10.15.1
Which browser are you using?
Google Chrome
N/A
No.
Iāve been using Dynalist for a few months now with the āDefaultā theme selected in my settings, and have always had the light theme. However, since yesterday Iāve been stuck with the dark theme after not changing any OS theme settings or Dynalist theme settings. I am not able to change the Dynalist settings to get the light theme back.
Image of default theme selected, but still displaying Dynalist with a dark theme.
