I want [[ generated links to have dynamic text, not fixed text. Can we make this an option if not the default?
Every time I type ā[[Mirrorā to make a link, it pops up a search thingy, I find the target, pick it, and DynaList generates
[Mirror/copy parts](https://dynalist.io/d/OspCW_9b6hfq5U0GvUnDn3T#z=TkhSHysguHG0-f6wovCO8Tx)
Then every time I must edit this to be just
because I want the link label to be automatically updated whenever the link target changes text.
(and if it were never to change, it wouldnāt matter).
Can we make this automatic? Make it an option to have [[ not generate [text](), and just expand to the link target?
If we had shorter internal links that would be much better.
(This could be skipped if you only have time to code the first one.)In Obsidian, if you edit a line you might see
Here is my line of text with a link to [[SomePage]]
In DynaList we see in lines not being edited:
Here is my line of text with a link to (āMirror/copy parts)
Then I tap the line and it goes wild:
Here is my line of text with a link to https://dynalist.io/d/OspCW_9b6hfq5U0GvUnDn3T#z=TkhSHysguHG0-f6wovCO8Tx
I would be happier if instead dynalist had shorter internal links.
Here is my line of text with a link to [[fq5U0GvUnDn3Tasteuaeu]]
Obviously still presented when not in edit mode as
<a href=https://dynalist.io/d/OspCW_9b6hfq5U0GvUnDn3T#z
=TkhSHysguHG0-f6wovCO8Tx>(ā Mirror/copy parts)</a>
Making the generated text much briefer would greatly smooth editing like in Obsidian. It also presents a hook for editing that line to sub in a different target.
