Android stuck at loading animation
Open application. Log in.
A list of my notes/my currently opened document.
Never ending loading animation of the Dynalist logo.
Which browser are you using?
Dynalist android, version 1.3.6
Android 9, Lineage OS 16.0
I’ve tried logging out and in again. I’ve tried hitting refresh. I’ve tried uninstalling and installing the app again. Not working.
I can click the upper left hamburger menu and see the names of my latest documents. When I press them they get marked as active/opened (bold text) but main panel of the application is still only showing the loading animation.
I have the same symptom (Android 9.0 stock Galaxy S9 plus). Concurrently with noticing this symptom, I also noticed that one of my files on the phone is out of sync with the same file accessed through pc. I think that the starting animation occurs while the mobile app is trying unsuccessfully to reconcile a sync. I can click on a file in the side pane while the starting animation is in progress and then I can edit normally.
We were able to reproduce this issue and it will be fixed in the next release! Sorry for the inconvenience.
Great! Thank you.
