You can see in the gif above, that I have a tag at the start of the bullet point, which had 3 lines. When I cut+pasted at the end of the line, it only had 2 (as intended). Then I repaste back to the beginning, same error occured
Text was supposed to be 2 lines long, not 3 lines.
text was 3 lines long
Windows and Chrome
see first link
! We’re cleaning up the bugs and would like to know if the bug is still happening to you? If not we’ll close this bug
