Autocomplete tags when searching
How about allowing the auto-completion feature also in the search box same as Workflowy?
Quick way to filter tags when using Ctrl+F (search)
Why autocompletion is not working in search field (for tags)
Auto complete drop down menu for tags in search bar
Excellent idea. I think the only reason we haven’t done it is time.
In at least half of the cases you would click on a tag to start searching, so we didn’t think of this feature as a high priority. Nevertheless it’s something we’re happy to do once we have less on our plates :slight_smile:.
+1
I would consider this a top priority!
@Erica, that is actually not my typical use case. I would say clicking the tag is <10% for me, if that.
Most of the time I want to quickly filter a list, by project or customer name. So I would hit find, then type @D expecting to look for @Dynalist entries. Currently we’d have to type out nearly the whole thing, especially for tags with similar first few letters.
I see, I can see why that’s a pain point for you then.
Bumped this up in our todo list :slight_smile:
Bump.
A handy feature in Workflowy – when a search begins with a tag symbol – # or @ – a list of matching tags pops up that filters as you type.
For example – search for “#f” and you’ll see a list of all tags that start with “#f”. Type another character such as “#fa” and the list filters down to just tags that begin with “#fa”. This is very fast and easy to use.
It is much faster to use than the Tag List pane in Dynalist.
Please consider this as a feature request.
Thank you!
dgg
#7
FYI…I just checked and did not see this on the Dyanlist Roadmap https://trello.com/b/z0HxDPNo/dynalist-roadmap .
Is there something we need to do to get this nominated as a feature candidate?
Thx!
dgg
