How do others archive projects with many steps that do not have a recurring date (on Pro) but may be reopened at some later date - or not? How/where do you save them so they are not deleted but also do not take up space in current folders or documents?
I have an ARCHIVE folder in the File Pane and I put documents in there after marking them “Archive” via the document right-click menu.
The Archive functionality was announced last month…
You can find the “Archive” option in document right-click menu. After you archive a document, it will be excluded from global search results. For better performance, the document will also be unloaded from memory when it’s not being viewed.
Thank you so much - missed that announcement; I must not be on some list or am not checking wherever I need to be checking. Your suggestion sounds like a good strategy. Much appreciate your time and input.
You’re welcome.
The announcement comes from the Monthly Blog at Dynalist Blog
Some other links you might find useful…
Help Centre
Roadmap for future development
Dynalist System Status
Twitter Feed
Thank you for those. I’ve been simply tooling along with the basics; time to learn more about what I’m doing!
