When on any bullet point, press shift+enter to create a note, start writing the note a few lines long. Pressing down key inside note, make the cursor go down, pressing up, makes the edited note close and the cursor to jump back to parent bullet.
When pressing up on keyboard in note, it should go up in the note and not assume you want to exit the note. It becomes such a irritation to write coding notes when it keeps popping out. To go up you need to use the mouse
Jumps out of note to bullet point.
Any
Brave
Latest
No third party scripts
