Type a UNC path (\server-name\share-name). This post is also mangled. Double backslashes display while editing, but disappear when posting. Single backslashes do not disappear. So, single and double look the same. \\ (3 backslashes show as two backslashes)
After leaving the section, the first backslash disappears.
\\server-name\share-name
Windows 10 Pro
Which browser are you using?
Google Chrome
Nope
Nope
If I enter 3 backslashes the result has 2 backslashes.
However when I export the outline I see 3 backslashes.
Same thing happens when I post this topic
I guess consistency is part of the issue.
Can I add a different non-printing character before a backslash for it to be literal?
I did see the Topic “Windows paths don’t show backslashes due to escaping”, but that didn’t seem to address this situation.
