When mousing over the the hamburger menu icon for a document title or zoomed title item the tooltip is obscured by the file/bookmark/tag pane.
Have you turned off the ācenter align documentā option? Or have you resize the window? It doesnāt look like it would happen in normal cases.
Yes, ācenter align documentā is turned off. Issue occurs whether window is maximised or not, or if Chrome full screen (F11) is used. Using Chrome zoom does not change anything either.
Sorry for the really late reply!
Yes, I just confirmed it. Seems to happen if the left pane is resized to be wide enough. Will fix!
Fixed! Thanks.
