On iOS selecting some text is not possible
I on iOS can select text. More details required?
If you’re trying to use the swipe to select text on iOS, and it activates the swipe to delete/check item, we’re rolling out a new update soon that will fix it!
Thanks for the help, I think long tap to select still works in the current version, but the new iOS select doesn’t quite work. The new select mode that doesn’t require long tap and you just drag your finger across the text to select it. That might be what @Irakli_Safareli was referring to.
looks like I had old version, was fixed after update.
