Tags sometimes include trailing spaces and merge with words
as you can see here, my tag merged with my generic texts. I only started seeing this today, never had this problem before
When clicked on, you can see that its treated as one singular tag
All I have on here is a color mod using CSS, but it wouldn’t change the functionality of clicking the tag and getting a whole string in the search bar
I expected just a tag by itself
Tag merged with the trailing space after, and words afterword connected to that trailing space
see below
windows and chrome
Could that be related to my theory that these tags come from scripting automation?
I noticed this issue occur when writing manual tags though too, when I had used ā€œ@tagsā€ which I write all manually
Hi @Vincent_Tang,
Looks like there’s an invisible space (non-breaking space) after the first tag (#W11A). If you delete that part and re-write it again, it should work.
It’s not easy to type a non-breaking space… did you copy that from somewhere?
We’ve patched our system to fix this, but if you want it to work you can manually rewrite it. Sorry about that!
well this was what I was mostly using, this phrase express line (and its settings)
does this nonbreaking space have anything to do with carriage returns or linefeeds?
or ascii control characters (1-32 values)
Was just curious so I could learn more about it
Yeah, that sounds like it. Basically any character that’s invisible to the eye.
We’ve patched it though, so you can keep using your script in the future just fine. No need to modify it.
does that also resolve the other really similar post I made at same time? (using tags breaks up text at start of bulletpoint)
Erica I still have problems with this still
Both this thread issue, and Using Tags breaks up text at start of bulletpoint - #2 by ruud
We haven’t released our fix yet, is that what you’re talking about?
ah okay yes that answers the question
Sorry about the confusion, I’ll update in this post when it’s released. Thanks for the patience :slight_smile:
Update: this should be fixed now in the latest version.
