Create a tag with numbers and slashes (e.g. #00/00/00 or @00/00/00
Create a tag.
This used to create tags, however now it does not.
Windows 10
Brave
Dynalist Desktop 1.4.0
Custom CSS
I noticed another bug report where a user mentioned that ‘#3’ or such did not create a tag, and the response indicated this was intended. I hope this is not the case here, as it would be very annoying after having used this system since I started with Dynalist.
Oh I know what happened. The recent change was that many punctuation/special characters are now excluded/disallowed from tags, which made your tag @1/01/20 get recognized as @1 instead. It seems like tags require at least a character that’s not a digit, so @1 wasn’t even recognized.
This change was put in about 2 months ago, at least on the web version. Originally, the fix was intended to catch situations where one would write @person1/@person2 which would be recognized as a single tag (See: Mentions/tags include common punctuation)
I’m thinking a solution would be to treat / as part of the tag unless the next character is #, @ or a space character.
