You are right, that was my first time uploading images from mobile. But both “Use mobile only” and “Use true black” under Mobile settings were unchecked.
Actually, just tried uploading over WiFi and I get the filename in the box after the upload. But there are still two problems:
The images can only be viewed by opening a web browser, which shows me a 403 page until I log in again in the browser (a problem given that I browse Private Mode in Safari). Is it possible to view the images w/o leaving the app?
The images do not upload if I try to insert them at the end of the list. See the video in PM.
With WiFi disabled, images seem to upload fine too (again, not to the end of the list)… Heisenbug!
P.S. Apologies for not finding the original thread.
Nope, not caching in the network. But when you mentioned caching, I logged out and in in the mobile app and now images render well and I can insert images to the beginning of the list. Still can’t insert them at the bottom of the list…
