Count selected items
i.e. if You select three bullets there is small count window which shows how many You select.
Word count
This should be discussed on forum how this should work but IMO words should be counted inside the parent node
BTW I would like to list More effort feature to implement
Node clone/cloning
You make a clone of a node and once You change in first node this also applies for cloned node
Send e-mail to dynalist to create new node
Connect Dynalist to IFTTT/Zapier or else
Maybe the simple feature are easy to implement so You can do it “meantime”
If You could let us know what do You think about it.
Or community can help to implement this
Many of these can be found on our Trello roadmap. Make sure to vote for them as that way it’s easier for us to see how popular a feature request is, as it’s nearly impossible for us to go through all posts on the forum when we want to remember how popular a certain request is.
3 in the first list and all 3 items in the second list can be found on the roadmap. Thanks again for your suggestion.
