Enter search text, go to the result. Good.
Then, delete the search term from the search dialog.
The cursor should remain where I placed it, in the searched / found term. Thatās why I searched for it.
I get returned to top of my doc where I started, as though I hadnāt done the search.
First noticed in Win10, Firefox (latest update).
Same behavior in Win10, desktop version.
