In Safari on a web page, click the share extension button. Then click Dynalist. This pops up a form with cancel and post buttons. Click post. This opens up Dynalist.
Should see an entry in my inbox destination with what was entered into a form and the url.
No entry added in Dynalist.
Safari on iPad, Dynalist 1.3.2
Safari on iPhone, Dynalist 1.3.2
I’m experiencing this issue as well. iPhone XS Max running the current version of iOS
It showed up in the same update that brought the pasting issue reported elsewhere in the forum. Also the splash screen has a black background instead of white, which might be intentional but looks like an error.
