Kind of like the Google Docs app, with how you can choose between editing something and then just reading it so that way if youāre on a touch-based device, you wonāt be distracted or mess up anything.
Thanks for the pointer, Iāll check out how Google Docs app does it.
They basically have a floating button near the bottom right corner of the app.
Yeah, I just tried. I took the āCheckā icons to mean āIām done, letās go back to the view-only modeā, which wasnāt super obvious to me. Maybe itās because Iāve never used the Google Docs apps; it does seem easy to get used to once you understand it.
I was thinking about adding a lock here. ![]()
To be fair, they used to have that for Google Keep and then switched replaced it with a bottom bar.
Or some other icon that has a similar meaning.
Lock was used for read-only shared documents, so it could cause some confusion (āDoes the lock mean to make this document read-only to other people? Is it reversible?ā). Thereās no tool tip on mobile, which only makes things worse.
Ah, thatās a good point. So something like a book, sort of like Readability.
Yep, something like a book or a lamp that indicates āreadingā would work. Thanks!
Update: this is implemented, waiting to be released. Woohoo!
I see itās released. Thanks a bunch: This was my single biggest annoyance and itās fixed. ![]()
Just leaving a minor note here: The only thing left to do is to remove the menu thatās accessible via pressing and holding a bullet (from all modes), which is accessible in read only mode.
This may be an issue if oneās phoneās lagging and then someone ends up tapping on something they regret by accident. So please keep this in mind if your phone lags at times and youāre using Dynalist. Fortunately the expand all appears to be the option that youāre most likely to click.
Thanks for the note!
Hi Erica,
Awesome on Mobile so far.
Can this also be done for macOS and Windows to only scroll no formatting only option to check off or move an item or node to another place. Still see the Image or files.
Cheers
Dimitry
That would be nice.
Do you think you would toggle this setting on desktop very often? (Iām trying to think where we should put it: hidden in the main menu or along with the search and eye icon?)
I think this an option i used very often, please Put beside the search and eye Icon
Cheers
Dimitry
Is this feature going to be implemented? I love to have it implemented on the desktop/web version because I work on multiple screens.
I do not want to accidentally edit my note in Dynalist!
Hey team, I also have just realised how useful this could be. There are documents that I certainly donāt need to risk editing once theyāre done ![]()
- As a developer, I often have code snippets saved in my dynalist. With a āread onlyā mode I imagine Iād be able to copy the text āas isā (I know that this functionality probably overlaps with the WYSIWIG feature).
I would find this useful for the desktop as well. Thoughts? @Erica
