I’m not familiar with linux so I may be being dumb but I have done a fair amount of searching and trying different techniques and I am still failing to install dynalist’s linux app on my chromebook.
(I’m very keen to get offline access on my chromebook)
I tried following this on how to install dynalist for linux: “After you’ve downloaded the tar.gz file, open it, then right-click and extract the folder that’s inside, to a place where it won’t bother you, nor be accidentally deleted.
Now that you’ve done that, open the folder and simply click on “Dynalist” and it should open the app without requiring anything else.”
… but no luck. I just got “This file type is not supported” when I clicked on Dynlaist.
Looking for specific info on installing linux apps on a chromebook I found a few suggestions -
use a .deb file (I couldn’t find one)
typing " sudo apt-get install dynalist" - no luck
or installing Gnome software Centre - doesn’t seem to have Dynalist.
Assuming your Chromebook supports Linux apps, you should be able to do tar -zxvf file.tar.gz on the command line to unzip it. As far as I know, it’s a portable installation, and it’s just a matter of unzipping it. .tar.gz is not an executable file format.
Thank you for the response.
I have managed to unzip it. The problem comes in then running it.
I have tried clicking on the file named “dynalist” as suggested in this post How to “install” the Linux Beta (from a while ago)
But I just get the error message saying “file type not supported.”
(My chromebook does support linux - it’s an HP X2)
Thank you Shida and Craig for your suggestions. They seem to have helped things along but not fully solved the issue.
I now get the following response in the terminal:
Logging to /home/timjwebber/.config/Dynalist/dynalist/dynalist-2019-5-3-17-40-19.log
Platform: linux
App path is: /home/timjwebber/dynalist-1.0.4/resources/
Data path is: /home/timjwebber/.config/Dynalist/dynalist
[App] /home/timjwebber/dynalist-1.0.4/dynalist
[App] App running, version 1.0.4
[Updater] Checking for updates…
[Updater] https://dynalist.io/standalone/check?platform=linux
[Loader] Trying to load main file from /home/timjwebber/.config/Dynalist/dynalist/packages/dynalist-1.1.20.asar/main.js
[Loader] Executing main function
Dynalist loading /home/timjwebber/.config/Dynalist/dynalist/packages/dynalist-1.1.20.asar
/home/timjwebber/.config/Dynalist/dynalist/packages/dynalist-1.1.20.asar/www/index.html
[Updater] Done checking for updates.
Then it just hangs…
I have tried looking around for suggestions to see if there was another library that may have been missing and tried a few things but no luck there. Any further suggestions would be welcome.
I have the same problem as the above user on my chromebook. Executing the file in linux does open it, but the terminal hangs with “[Updater] Done checking for updates.”
Any suggestions would be welcome! I’d love to get it working.
Have just posted a “how-to” on installing Dynalist in Chromebooks; including having its own icon; hope this helps. See attached docx.Install Dynalist on Chromebook.docx (273.4 KB)
