Right now, if I want to do a presentation I first create an outline in Dynalist, then do a bunch of RegEx find/replace commands to import it into Deckset. Or, if I’m feeling lazy, I use Dropbox Paper which has a half-decent presentation mode. It would be great if I could just keep everything in Dynalist and do the presentation directly from there. I also think this would be a killer “pro” feature that might encourage many people who are holding out to get pro subscriptions.
To answer @Erica’s questions: I imagine it working something like this:
- All 2nd level items start a new slide, with sub items as bullet list.
- Any item with a note are a new slide: item as title, sub items as block quote
- All items with images are a new slide: making the image a separate slide, with the text - or note - as caption.
- If an item is too long to fit, it starts a new slide, or gets broken into multiple slides.
I know from using tools like reveal.js and Deckset that it is fairly easy to adapt to these conventions. So once Dynalist specifies its own approach users will be able to prepare their outlines accordingly.
