Thanks @Piotr
Hi @Piotr
Iām a little late to this discussion, but if youāre still investing in the Zettelkasten method, you should seriously look into TiddlyWiki https://tiddlywiki.com/
Itās based on the concept of atomic ānotesā, and is highly relational. itās portable, cross-platform, and infinitely customizable (interface and otherwise).
Given your work on Powerpack, youāll likely be interested in checking out the google group:
https://groups.google.com/forum/#!searchin/tiddlywiki/bobexe|sort:date
and, more specifically, Jed Cartyās work on BobEXE. Look also into the other addons, and customizations (TiddlyMap comes to mind) to get an idea of the capabilities of this system.
Iāve argued repeatedly on that platform that the ONLY thing missing from TiddlyWiki is a good, well-defined user interface, that provides the functionality users want out of the box. An outliner/note taker like Dynalist, a mind map utility like Freemind, etc. All of these are possible in TW, itās just cobbling together the pieces in a coherent interface that holds this system back form being the be all and end all of personal data management. They could use your talent towards that end.
Thank you, I was playing with TW and I liked the idea, itās brilliant software, but after reading more about it I gave up - there are problems with bigger repositories, app gets slower and slower over time. Iām done with looking for solutions, I built already my own app for ZK, GTD and spaced repetition, all in one place and interconnected, maybe I will release it in the future
At first glance this looks similar to an older program called NoteStudio. I invested a lot of time in this database, but the software was eventually abandoned. I feel more confident in the commitment of the Dynalist team.
The upside of TiddlyWiki is the code and the data are completely open. If TW dried up (wonāt happen, they have a LONG history), you still own all your data, and itās simple text. No proprietary formatting or storage.
I have heard people complain about extremely large data sets slowing down, but the tests Iāve seen usually demonstrate that such isnāt really the case. The limitations are the browser and/or the plugins you use to do the work through. In any case, thereās a lot of potential there, if you can find a combination of plugins that you work well with. Itās hard to beat the minimalist Dynalist interface for quick and easy entry.
Iām interested to learn how to make my own hacks for dynalist. Like whatās the first step in making Powerpack that I could follow? The pack itself doesnāt have much Iād want to use, but the How is interesting to me.
My guess would be to play with the console, see what variables there are, and what do they represent. A good entry point is the below:
You can see in DYNALIST.app there are a bunch of things.
This is, of course, the hacky way though. Our vision is that soon weāll be able to clean up the endpoints and document them, so you can properly use these interfaces and get notified when they change. Weāll try to keep them the same if thatās possible, but sometimes changes may be required. Right now changes manifest themselves in randomly breaking Powerpack ![]()
Weāre preliminarily calling this the āplugin systemā. Itās the client side/frontend counterpart of the data API.
Hello, Is Powerpack 3 still working? Seems like superior tool, would love to use it.
Trying to install according to steps in manual, seems like itās installed and active. But the only change occured is the ā+ā button left to āsearchā.
Any idea, how to make it work?
My bad, completelly missed the āOpen powerpack settingsā option in right corner.
Is there any sort of tutorial for putting all of these features to use? It seems powerful, but frankly a little overwhelming. Like what is an agenda and how do I benefit from using it?
Hi @Piotr, thanks for your amazing work!
I need a feature which Iād be willing to develop myself, so I have 2 questions:
- Is there any way to contribute to your extension (by a pull requests and such)?
- Is this feature already planned? In Spaced Repetition, I need to be able to use a breadcrumb of a nodeās ancestors as the question. It would be very useful in order to memorize a whole tree. Also, I would love to be able to create a bunch of SR items from a list (or better, a tree) of nodes, just selecting a template to apply to each of them.
Bug report: on the Electron app, custom CSS does not apply to panels and popups.
Chrome 76.0.3809.132.
Code highlight not working.
Just a fair bit of warning to everyone using Powerpack:
The internals of Dynalist is getting quite some change (in terms of naming and code structure). Since Powerpack uses some of our internal code api, that means there will be broken functionality.
Weāre working on a fair amount of internal changes in preparation for some of the big projects weāll be working on, but hopefully these changes will be done by the end of year and everything after that will be new and wonāt be major refactors to the internal code structure.
It does mean that powerpack will and might continue to be broken until at least the changes can stabilize.
@Piotr I can pm you a list of major changes when they hit, but it doesnāt seem like thereās a lot of activity here recently.
Gulp! Powerpack is so integral to my workflow. Your warning is much appreciated and I hope it can co-exist with the new Dynalist.
Gulp! Powerpack is so integral to my workflow. Your warning is much appreciated and I hope it can co-exist with the new Dynalist. Good luck with the development. Weāre all very curious to see what emerges.
Agreed! I really would love to see Dynalist bake in PowerPack features. Without this and with broken PowerPack functionality, I might be forced to migrate to Notion. I would rather stay with Dynalist in an evolving, flourishing format!
Well maybe the big project is a proper plug in system that allows building a Power Pack with stable functionality
Thanks for the clarification! Iām running Powerpack 2 and noticed yesterday that I canāt follow Dynalist-internal links and Powerpack was the culprit.
Guess, I have to work without Powerpack for some time. I still have my fancy custom CSS, though.
Since Piotr seems to be inactive, I could look into patching powerpack to keep it alive.
I didnāt realize people are still using Powerpack 2⦠Do we have a good idea how many people are using 2 vs 3?
