Hi
click on hamburger icon in top right corner, click on âOpen powerpack settingsâ - enable what you want
I was looking for that already yesterday, but the thing is that nothing from DPP3 injects for some reason. (also tried the âclick this linkâ method )
Iâll show what I see top right, and Tmonkey settings.:
Oh getting closerâŚ
Wtih the manual injection i did manage to get to âPowerPack settingsâ ! yeey.
The only clue left is regarding why Tampermonkey fails to do the same, but I will figure that out sooner or later, I can live with this already.
Thanks for the suggestion!
there is also https://chrome.google.com/webstore/detail/violentmonkey/jinjaccalgkegednnccohejagnlnfdag theoretically it should work too
Hey, I get the following error when I use the agenda:
Can somebody help?
I had those all the time, nothing to worry about. If something is not working there will be different cause.
Alright. Thank you! I fixed it by copying the PP3 documents again.
If you want them sorted by date, you canât have them grouped by date
If you want them sorted by date, you need to uncheck âgroup items by dateâ. Grouping is useful only when you have some other way to indicate that item is under some date, you can then filter items by pattern of the date. Iâm not using this anymore, maybe someone else will be able to show an example of this.
Hi @Piotr
Did you try https://www.notion.so too?
Yes, I do. I tried every option from https://alternativeto.net/ (and https://news.ycombinator.com/item?id=12794292 and more) related to writing / note-taking / project management for Mac (or as web app), there is really no way for you guys to propose something I didnât try before, Iâm actively âresearchingâ this area since 2015
Bear is the best for ZK, no doubt about it, and Dynalist is IMO the best for everything else, I personally donât see any compelling reason to use Notion, but if you need tables or something else they have and Dynalist donât, then it might be good for you. But if youâre asking because youâre looking for ZK app then IMO Notion would be one of the worst choices.
Thanks for this powerful plugin! Especially for the âSpaced Repetitionâ feature. I have one question related with it:
There are 10 options to choose every time. Some options have the same âspaced daysâ. For example, there are 5 â1 dayâ options in the image below.
- Which algorithm are you using? Similar with Anki?
- In General, whatâs the best practice to select the option? Whatâs the effect of choosing different â1 dayâ options?
Thanks very much!
Youâre welcome!
Itâs http://www.blueraja.com/blog/477/a-better-spaced-repetition-learning-algorithm-sm2 with some modifications so the dates are more spread in later stages
Itâs not important at the beginning, you donât need to look at the dates, just choose what you feel. Later you will see bigger differences between them. My problem with Anki is that sometimes the choices it gives are between <10m and years, when Iâm not so confident about years, but also donât want to start again from zero.
@Piotr, Iâm afraid that the dreaded day has come and one of the features of Powerpack no longer seems to work. When I click on my customised Workspaces, nothing happens. There must have been an update to Dynalist or Chrome that affected this.
They changed name of one function, nothing complicated, you can update the script to 3.3.1.
Works fine again now. Thanks @Piotr
Hi @Piotr
I just started using PowerPack. Is it possible to search by all my Dynalist documents in Agenda? How to set the url for this?
I donât remember
if itâs not described in documentation then only real urls for chosen documents are accepted, one in line.
