Open a mind map view on any touch device and try to navigate and pinch-zoom on the screen.
I would expect to be able to use touch. I would also expect to be able to edit from this view and add new nodesā¦
But nothing. It only works from the trackpad and no editing capabilities. It seems gimmicky rather than functional. I would love the mind map ability. It makes perfect sense to add this functionality into Dynalist. Just need to really work.
Tried it on Android and Windows.
