Choose any Dynalist node that contains Markdown markup for inline code and / or code blocks. An example node would be the following, shown as entered into Dynalist:
Node has `inline code`, a line break and a code block: ``` I am a code block. ```
Export that node to HTML from the node’s context menu.
The resulting HTML should contain suitable elements to render code, such as <code>…</code>
and <pre>…</pre>
The resulting HTML contains the Markdown formatting verbatim and consequently does not render the code in any visually distinguished way.
