When we get a link to a bullet, and the paste it on another bullet, it gets formatted to the linked bullet content.
The URL only appears when the cursor is on the item.
The problem is that the search doesn’t find the formatted text, but only the URL text.
I could use the to create a link, but it slows down the workflow.
You mentioned you could use [] to create a link but it slows down your workflow – in that case [[ is perfect for you! You don’t even need to leave where you are.
About the trello card, that’s a nice and smart feature. Helps a lot to understand what you’re working on.
But I would keep the suggestions to improve the search.
The way you made the search display is really helpfull. What–I think–it’s lacking is finding more than “what catches the eyes”.
When I link to something outside the scope, outside the document, it’s now part of the scope.
You link and cross-reference better than the competition, but finding the content that comes from using this core feature is hard, because the search catches only the text.
OneNote has a feature to copy links to paragraphs. When you paste this link on another paragraph, it too makes it friendly, but the search finds the friendly text.
Just thought… when you implement WYSIWYG, will the search work differently?
I guess it’s doable, but unfortunately it’s not high priority right now, we’ll keep track of this improvement! (If you like this feature request too, please like the original post)
