Created from: Article View; can not view compact
Switch to Article View on desktop web browser
Attempt to adjust list density.
Expect the Article View to change density when I select a different density of option.
Nothing seems to happen. Maybe the change is subtle but I don’t see any difference as I can when making the same changes without Article view.
Which operating system are you using? Mac OS & Windows
Which browser are you using? Chrome and Safari
If you’re using a desktop or mobile app, what’s the version number of Dynalist? n/a
I believe it’s always been a thing since I started using Dynalist about a year ago.
I keep thinking it will be fixed, but then I was unable to find anything on the topic
Like you said, I don’t think it has ever worked before, as the list density settings only apply to the list items.
