- Use āDarkā Theme
- Create Vector in KaTeX, i.e.:
$$ \vec y $$
Background stays #181818
, Text stays #eee
A rgba(255, 255, 255, 0.3)
rectangle appears over the vector
Which operating system are you using? Solus 4, Linux 5.3
Which browser are you using? Chrome 87
If youāre using a desktop or mobile app, whatās the version number of Dynalist? ā
Are you using any third-party scripts for Dynalist, e.g. PowerPack? ā
The overlay is created by KaTeX internally and has the class .overlay
, which happens to be a common class name and is also used by dynalist itself (For me in theme_dark.css:65-67
), where the color is applied.
I recommend renaming the .overlay
class or adding an override rule for KaTeX environments.
Other issues suggest this is an issue with KaTeX itself, which i donāt think it is.
Love Dynalist, thanks for it!
Cheers
