Open and start typing
Responsive typing
Super laggy typing.
Which browser are you using?
iPadOS 13.4.1 (the one with mouse support - yay)
Iāve updated our test iPhone to 13.4 17E255 (I canāt seem to find 13.4.1 as it says I have the latest update). Havenāt seen any issues with the app performance wise compared to before. Our iPad is updating currently, but only to 13.4 as well.
Iām guessing 13.4.1 is a beta? I will test again once a new iOS version is released.
I just tried again (and Iām running on 13.4.1 on my iPad Pro). I see the same performance problem with my primary document. When I create a new document though, I donāt see the problem. My primary document is pretty big - 243KB compressed. Perhaps related to the length of the doc? Have you tried it against a large doc?
Thatās certainly a large enough size I would recommend avoiding on mobile, but if you say it worked fine on previous versions of iOS then thatās still quite suspicious. Iām upgrading our test device again to see if we can repro.
Updated and still not seeing an issue so far. Were you able to test if the issue goes away when you split the document up into smaller pieces? Hopefully that can give us some clue as to what to look for.
