Work on Chrome version of Dynalist while working on IOS version
The syncing should be prompt and not interfere with each other
It is very important to have faith that Dynalist sync will work properly and not loose data.
Syncing seems stuck or very slow on IOS. I lost work that I did on web while making updates on IOS. I could not even undo on web after losing changes.
Which operating system are you using? Mac and IOS
If you’re using a desktop or mobile app, what’s the version number of Dynalist? latest
