Right now it looks like the only way to add an item is to go into the inbox on my phone, try to click on an item without opening an associated link, enter to add a new item. It seems like it would be so easy just to have a little plus button that would add a new item to the inbox?
This is one of my biggest gripes with Dynalist. Itâs also a problem on Desktop/browser.
I decided to switch back to Things3. The new version gives me all of the features of Dynalist (outlining etc.) plus the useability of a task app.
Android? Try Quick Dynalist.
Here are the ways I typically add a quick item
- Use the Quick Dynalist widget (not app) icon on my Android phone, type into the popup, tap Add and it disappears into my inbox
- Press the Dynalist Bookmarker icon in my browser while viewing an important GMail message. It sends the email URL in markdown with the subject as the link.
- say âHey Google add xyzâ aloud in my house
- hold the side button on my watch and say âadd xyzâ aloud
- press cmd-space on my Macbook, type xyz, enter
Generally you send your quick note via an HTTP request using whatever software you prefer that supports HTTP requests, or rig up a scheme where it emails your personal dynalist inbox.
Itâd be nice if there was a first party quick-add widget on both iOS and Android but for now we have to be a bit crafty.
On desktop app and browser there is a quick add hotkey
My gripe is not with adding things to inbox, but adding things while actually using Dynalist.
Hereâs an example:
If I want to add three on the same level as two, I have to:
- click somewhere below
barand pray I donât click on the small area below it where nothing happens, or even further down where nothing also happens - press enter to make a new node
- press shift tab to go down one level (or more than once if youâre several levels deep)
This is two more actions than the way you do it in Workflowy, which is just clicking the +
, regardless of how deep you are:
Things get worse if the last node is a link, as thereâs a rather frequent bug in Dynalist that puts the cursor in the middle of the link (between the [] and the ()), in which case youâll have to press Ctrl + End before pressing enter. Thatâs now 4 steps, just to add a node, which is the whole point of the application. Workflowy also has no such problems with links since theyâre not markdown (and theyâre honestly even easier to edit).
I really like how customizable Dynalist is, but at this point Iâm seriously considering going back to Workflowy where itâs easier to perform basic operations.
I fully agree that dynalist on mobile isnât fun to use. Thatâs why I only use mobile for 2 things - the inbox widget, and the swipe to delete function, both on a 3rd party app. Otherwise I just reading. Iâd assume workflowy is just as bad, but I havenât used it. Mobile just isnât a good platform for these kinds of apps imo. Imagine editing a Google Doc on phone. Mouse and keyboard is great tho.
I read the topic as iOS but I now realize youâre talking about windows/mac/linux
No, you want to click to the right of bar, then press enter twice.
Again, click to the right of the last item, works better
But that little hover plus is a good idea. Dynalist should consider adding it.
The example was where bar would be the very last item in the node. Clicking below bar is way easier than on the right of it. Specially for links where you have to be careful not to click on them (there really should be an option to use Ctrl + Click to open links, rather than a mere click).
Click bottom of node, right of node, it doesnât change much. In fact, for nodes with links, it seems to cause the bug more frequently.
Example:
Also, the other problem with clicking on the node itself is that thereâs a space in-between each node where it actually goes to the start of the nodeâs text, rather than the end, which again makes editing an unreliable and frustrating experience. If youâre adding nodes fast, you click to the right of the node to add a new one, but ever so slightly didnât click in the middle, so it goes to the start of the node, so you press enter to add a new node, and it ends up adding before it rather than after. It just breaks the flow.
This small strange area also doesnât work with drag selection.
Make a new post in Feature Requests with a title like Node insertion with mouse needs improvements since your ideas might not get seen in this thread about Quick Add to Inbox in iOS
One thing Iâll say is that any action in dynalist that requires more than 1 keypress or click, but is always the same sequence, can be re-mapped via keyboard macros. I personally use quite a few, and it makes using dynalist much better. I have single hotkeys that move items to certain nodes, that âshuffleâ a sublistâ, that read an item aloud via speaker, etc. Thereâs even a 16 step macro, which emulates the [[ create wikilink function in obsidian/notion.
I have always thought that #Features were for feature requests. But maybe this isnât so. So much to know in this universe.
