It appears impossible to insert a line break within an item on mobile Dynalist.
In the iOS app, if you use the default Apple keyboard, you can press the SHIFT key, and then ENTER, which does insert a line break within the item – but, I use the SwiftKey keyboard, where this doesn’t work.
In the Android app, it appears to be impossible by any means. SHIFT followed by ENTER works neither with the SwiftKey keyboard, nor with the default Android keyboard.
Could this action (“insert line break”) be made available, perhaps, for activation for the newly customizable toolbar at the bottom? Thank you.
