- Create any new bullet point
- Add some normal text
- Add some link target text
- Make target text a link (ctrl-k)
- Click any other bullet
- Try to click ‘the far right’ of your text and link bulleted entry.
Lorem [Linkum] (URLDatum) [insertion-cursor]
Lorem [Linkum] {insertion-cursor} (URLDatum)
Windows 10
Which browser are you using?
Chrome
Yes, most recent PP3 and Custom CSS
Generally, when I click at the end of a line, I anticipate being able to start typing right away, so muscle memory has me typing in the correct location each time. So, I then have to cut/paste to end of line.
