I want to use dynalist to deal with plain text tables which contains chinese. i have tried all the fonts in settings, none of them are fix width font for chinese.
thanks.
thanks.
Chinese characters are “fixed-width” by default, aren’t they?
I tried inputting some random characters in Word:
So technically all fonts should work for the Chinese characters to line up.
sorry i didn’t make myself clear, check below images:
i create tables in https://www.tablesgenerator.com/text_tables
in dynalist:
in notepad++:
when create tables contain chinese and english, the table border can not show like notepad++.
is there any way to set my own fonts?
thanks.
i found a solution to set custom font, so this problem is solved.
use a custom css below:
.Document-rootNode.u-use-pref-font,
.is-mobile .LeftPaneContainer {
font-family: “黑体”;
I see, so it’s about keeping the width fixed when mixing with Latin characters.
Glad to know you’ve found a solution to it!
