I’m using the Dynalist Windows application. How can I save my document to my local disk?
The app automatically saves to your disk. If you see Saved or Synced it’s done. If you want to import the data into another app, go for the Export command.
Thank you. I had a problem finding the Export command, but I now see that when I do a context-click on the filename in the “My files” pane, there is indeed an “Export”.
