With Dynalist Pro not currently linked to Google Calendar, attempt to link my Google Calendar.
Get the usual Google security request to allow Dynalist to link to my Google Calendar.
When I click on link, it returns to Dynalist and says “null” calendar is linked.
After that page is closed, when I return to Dynalist app, it says no Google calendar is linked.
That Google Calendar is linked.
Windows 10 and Chrome Browser73.0.3683.103 (Official Build) (64-bit),
Desktop App is Dynalist 1.1.19.
