Global hotkey
there should be global hotkeys to add new items to inbox or for searching.
https://talk.dynalist.io/t/quick-add-to-dynalist-inbox-using-autohotkey/4118
https://talk.dynalist.io/t/chrome-search-engine-for-dynalist/784
Om Mac, CMd+Shift+I wont work as expected. It brought up small textbox that which you can not paste image there.
On the other hand there should be search modal form that bound to some global hot key. Scripting is not a solution.
these are very small but necessary features that prevent me to buy premium.
