Create an item like this: test markdown item with link in brackets ([link](https://example.com))
Click Export → Formatted
• test markdown item with link in brackets (link)
The closing bracket gets glued up to the end of the link, breaking both the formatting and the link
Dynalist macOS app
(You’re currently running Dynalist 1.2.0. Dynalist is up to date.)
