- Select part of text from one bullet using mouse drag
- Move this text to append to the text in another bullet (also using mouse drag)
- Undo using ctrl + z
The text gets deleted from its new place and returns to original place
The text gets deleted from the new place but is not returned. The actions carried out prior to this process get undone.
Windows 7 Desktop version
