trying to embed my dynalist into notion, not sure how to make it work tho.
Try the last comment here:
There seems to be some sort of authentication issue I suspect is on the Notion end. The embed goes to the login screen even if using a public link from Dynalist and authentication always fails via login or Login with Google, etc.
It only works for dynalist documents that are set to public url
