Open a document containing a line with text long enough to wrap when the browser window is not maximised.
Click on the first item and use the down arrow to navigate the list
When the cursor reaches the wrapped line, [down] moves to the wrapped text, but a further press does not move to the next item. Navigation is stalled.
I expect the down-arrow key to continue navigation to the item below the item with wrapped text.
Navigation stops on the wrapped item. Down arrow key does nothing.
Windows 10 Enterprise
Firefox 63.0.1
Dynalist web application (browser tab)
Example document: https://dynalist.io/d/8NTP5Bev8rcvijOuKBcVHzIJ
Make browser full-screen, navigation works. Make browser small enough to cause item 5.5 to wrap. Now try using the down arrow to traverse the list. The cursor stops on 5.5 and will not move to next item with the down arrow key.
Oddly, navigation using the UP arrow works as expected (starting from below the wrapped item).
