Write anything, but make sure it has multiple words
Double click the last word so it highlights, keep mouse down
Drag to the left, the highlight on the first word is lost
This works in Gmail
It works in this bug comment field Iām typing in right now
This is a ādeepā mouse behavior that is unsettling when it fails
I hope itās a simple bug fixā¦
When you drag, the selection keeps the original word
This is how I select all of my text (well, I usually drag right but sometimes I drag left)
