Does it not drive everyone crazy that the cursor moves to the previous item after you move something?
I use move many times a day. Not crazy, just slightly off-balance.
I use move daily. I’m not sure I ever thought about where the cursor should go after a move. The current behavior doesn’t bother me, though I could understand an argument that it should go to the next item.
Where do you think the cursor should go after a move, @BigChungus?
It outta move the same way it does when you delete or cut or complete something – to the next item
Hmmmm … I’ve been using dynalist so long I don’t know if I’ve just adapted to it but now my natural instinct when I want to delete a lot of stuff is start at the bottom and delete up - it would annoy me if it was the other way now
