- Select some text
- Tap “Cut”
- Move cursor elsewhere
- Tap “Paste”
Cut text inserted
Old clipboard contents inserted. If clipboard is empty, Paste option does not appear.
Which operating system are you using? iOS 12.4, iPhone 8+
Which browser are you using? both iOS app and Safari
Don’t know how to find the version number in the app.
Are you using any third-party scripts for Dynalist, e.g. PowerPack? no
