Combine items easily
That would be nice. Not a deal killer… maybe something for pro users only…
No idea what you are asking for.
A BIG part of dynalist is pruning my inbox of thoughts. Sometimes I have several items one on seperate “nodes”. I have to use the keyboard to
  1. point cursor at the beginning
  2. backspace to combine node with previous node
  3. point cursor at the beginning
    … n) depends on how many nodes you want to combine.
It would be nice to instead select all adjacent nodes, and then via a keyboard shortcut combine into one.
Hope this helps
I think you can go a lot quicker than your current process with the excellent ‘select’ and ‘cut’ mechanics in dynalist
So firstly if you press escape to remove your cursor, you can use ctrl and click to ‘select’ an entire node quickly, or you can click into the node and press ctrl+a twice - ctrl+a once selects all the text in the bullet, ctrl+a twice selects the whole node, including the note
You can use this to select multiple nodes easily, then ctrl+x to cut them and move them all somewhere e.g. under another node if that’s what you’re after
For merging, if you ‘select’ only one node and cut it then place your cursor at the end of the bullet you want to merge it with and paste, instead of making another bullet it will just paste the text on the end (and even add the note text), so the cut mechanic can be used flexibly to either create a new node, or merge quite easily
I played around with this a bit and it’s really quite fast … I select and cut stuff to move them around as default
Hi Stephen, Thanks so much for responding, I’ll give this a shot and see if it helps!
Highlight and merge
