Thanks, the new colour labels are great! Do you have plans to make the colours searchable?
What are colour labels / How do you use them?
You will find the details on the Dynalist Blog:
"It’s really simple to use: open the item menu and click on the color you want. Click on the same color to remove it.
Even faster, you can use Ctrl+Shift+1~6 to apply color labels. Ctrl+Shift+` (grave accent) will remove the color"
blog post: http://blog.dynalist.io/color-label/
Thank you so much for the colour labels! Please make it searchable, but take your time. (Can’t wait for the other big feature mentioned in last weekly update!)
Yes, good news is that it’s pretty easy to do. Low-hanging fruit that would make things really convenient for you guys! ![]()
Is it planned to update the more option menu to make color label available?
This is implemented now, please see the search tip that pops up when you enter the search box.
You mean on the mobile version?
Yes. I mean the mobile version.
Yes, it’s coming soon!
Unfortunately the mobile version is always a few steps behind ![]()
