Hi there,
Last week the checkboxes for checklists disappeared from my dynalist. I can still see them fine on my phone, but not on my desktop.
Mac, running dynalist in the browser, chrome.
Use the shortcut to make something a checklist (that has been working fine for a year), or use the gui menu select âmake checklistâ.
The item becomes a checklist and shows the square box
The item does become a checklist (I can tell as the context menu becomes âunmake checklistâ isntead of âmake checklistâ. However, the square box is not visible. I can see the changes on my phone
Mac OSX Mojave, 10.14.5
Chrome and Safari
Myself and my team use Dynalist Pro for work, and this is affecting us every day. Please prioritise fixing it. Many thanks.
