- Open Settings
- Go to Keymap
- Click button to set a shortcut
- Hit
Delete
The shortcut for that action is cleared.
Nothing changes.
Chrome on OS X
Delete
Nothing changes.
Chrome on OS X
I don’t think Delete is accepted, nor does it appear in the instructions. The intended way of restoring (deleting) a shortcut is to click on the “Restore” icon on the right side of the shortcut.
It would be a bug if that icon doesn’t show up though.
Allowing restoring a shortcut to its default with Delete is a nice touch, but maybe it’s more appropriate as a feature rather than a bug?
Oh, I meant unsetting shortcuts, not resetting them. As in: no shortcut at all for a particular action.
Hm, yeah, probably. I think I expected Delete to work because it does in many other apps that let you set shortcuts.
Edit: Related: Unnecessary shortcuts? - #5 by Erica
That makes sense if you want to free up this shortcut!
I guess the obvious workaround is to assign it something almost impossible to press or get used by others (e.g. Cmd+Shift+Alt+Z). But I get what you mean, sounds like a nice-to-have little feature for custom shortcuts.
