Yup, that’d be ideal.
I’ve got a couple of items I’d like to add to the wishlist:
Moving items between documents (API)
- I’m not sure how the native clients deal with this - if they re-create & delete, then maybe just being able to optionally include the
createddate in the insert would be enough to mimic a ‘move’ between files.
- API to rename/delete tags
- Are tags stored/indexed separately on the backend? Or are clients doing the work? The latter would make sense if the data is stored as a single document blob.
- Ability to change a node’s
collapsedstate- I’d like to be able to set this value on the initial ‘insert’ of a node, as well as the ability to toggle it for an existing node.
Overall, great work on the API! I haven’t had any issues yet.
Nick
